Help with subwoofer pop - M&K MX-125 II
Contentt
Contentt
I purchased an M&K MX-125 II back in 98. Recently it's been popping during really loud movie scenes and wondering if I may be able to fine tune the settings, or figure out if I have a bigger problem.
Also, every time I adjust the base level it thumps wildly. Not sure if this is a related problem.
I'm using a Denon AVR-2802 with the Crossover frequency set at 100hz currently.
The M&K sub has these current settings:
* Cable plugged into Left/mono plug, never understood what the right plug was for?
* Bass Level: -3db
* Phase: +
* Low Pass Filter: set to Bypass
* Hz nob set at 85
engtaz
engtaz
Have you check the speaker physically. I the cone has separate from the foam/rubber that would cause you problem or the coil.
engtaz
Contentt
Contentt
Tweaked it...
I cranked the sub Low Pass Filter as high as it would go to 125 per a suggestion. After a few tests it seems to be working now without popping.
