I have a 10" Kenwood sub that i am using for my home theater, right now i have it in a 1.5 cu. in. sealed box and it wont go very low. So i guess i need to port it, my question is how big should the box be and how big should the port be? i tried making a box in winISD but i didn't know quite what i was looking at, it will be used mainly for movies and video games, with some music every now and then.
heres the specs on the sub.
Kenwood KFC-W2509
top mount depth: 4-9/16"
sealed box volume: 0.6 - 1.25 cubic feet
ported box volume: 0.75 - 1.5 cubic feet
Sensitivity 91dB
Frequency Response 28 - 800 Hz
RMS Power Range (Watts) 35-350
Peak Power Handling (Watts) 700
Top Mount Depth (inches) 4 9/16
Bottom Mount Depth (inches) 5 3/8
Cutout Diameter or Length (inches) 9 5/16
Vas (liters) 44.04
Fs (Hz) 35
Qts 0.42
Xmax (millimeters) 8
thanks as always for dealing with my lack of knowledge.
