I have recently purchased a new home and I am looking to upgrade the system for my living room. I have been using 3 PSB GT1's for my front sound stage for about a year now. I want to get away from the 3 towers and 2 subs in the living room and migrate to a wood finish instead of piano black. The PSB's will be going downstairs for a home theater I will be putting in next summer.
The rest of the system will be an Emotiva XPA-2 for the mains, Emotiva UPA-1 for the center, Emotiva UMC-1 pro, and dual Rythmik F15HPs. All of which I currently own and am using with the PSBs. I have been using 3.2 for some time and I want to stick with this until next summer. I plan on doing some work to the home and using in-wall speakers for the surrounds.
This will be used in the living room so it will handle both music and HT. However, my primary concern is music since I will end up having a dedicated home theater. I listen to mainly metal and I am hoping to find a bigger sound then what I am getting from the PSBs. I do want a set of mains that have a matching center since it will be used for some tv.
My living room and kitchen are actually one large room at this house, guessing 40x30x11-ish since I do not have exact measurements yet. The PSB's do not fill the area like they did at my previous residence and I'm sure this is due to the increased size of the listening area. I also have hardwood floors and some of the wall are dry wall and two others are cement with wood inlays, not certain if this matters.
The speakers are currently about 8 feet out from the wall to accommodate the TV stand. This also makes them around 8 feet from the couch, primary listening position. I have noticed that the audio sounds better at the kitchen table then it does from the couch. I want to go with a set of speakers that have a traditional center so I can push the speakers back and begin to correct the issues. I have other treatments to do but I want to start with the speakers since I am looking to upgrade anyways.
My budget is up to $4k for just the 2 mains. I certainly would not be upset if it were less but I would like to purchase a set of speakers I can be happy with for many years. The mains must have a matching center that is easily available to purchase a few weeks after the mains. I played hell with the PSB GC-1 and do not want to relive that experience again. I spent months attempting to purchase it but could never locate it, hence the reason I have a 3 tower set-up.
I have had large driver speakers in the past and have missed them since having the PSBs. I do love the clarity of the PSBs but they seem to be missing some power. I am not ruling out smaller driver speakers just stating my preference. I would love to have the best of both worlds.
I have been looking at the Aperion Verus Grand, Swan F2.2, and Swan F1.1. I have also looked at the Salk Archos and the Philharmonic 3 but I don't believe they have a center channel? The Swan F1.1 seems to be my top contender at the moment, I have seen it dip into my price range a few times. I am not certain if it is the best choice for my budget and I'm looking for the opinions of the pro's.
The PSB's were my first venture into good audio equipment and I need some help due to inexperience. I live way up north and I do not have any options to audition speakers. I do have a Paradigm dealer about 3 hours away but I have contacted them and it's they do not have a large selection for auditioning.
Any better ideas then the options I have listed above? Or opinions on what I have been looking into?
