bens0472
Hi,
I'm new to Audioholics and, admittedly, I'm not all that well-versed in audio technologies, but I have a problem that I'm thinking someone here might be able to give me a little advice on.
I have a Sony STR-DE545 receiver that I bought about 6 or 7 years ago. Slowly, I added new speakers until, about 3 years ago, I completed a 5.1 surround system with Polk R40s in the front, the PSW250 sub, R10s in the rear and, frankly, I can't remember the center, but it's one of their smaller ones and it's about 5 years old.
I'm also running two Bose Interaudio XLs that I got way back when I was a senior in HS in 1989 on the B channel.
For DVD, I'm using the Pioneer DV-333, if that information is helpful.
Ok - about 8 months ago, I started getting strange things happening. One day while my daughter was watching one of her Dora the Explorer DVDs, we heard some really lound static followed by kind of a real low frequency buzz. Then everything went silent and the receiver was flashing "Protect". Not knowing what had happened, I turned everything off and let everything cool for a few hours. The first thing I noticed was that the receiver had gotten pretty warm, likely because I hadn't allowed enough room on top between it and the (DOH!) CD player I'd set on top of it.
So, after a while, this goes away and them comes back and repeats. Unfortunatetly I can't pinpoint it to any of the devices because similar things happen when I'm playing CDs (with my kenwood CD changer) or when just using the Tuner. One thing I did notice was that my Polk speakers all say they are 8ohm speakers while the Bose jobbies say 4-8 ohms.
So, first of all, I had the Bose speakers, in channel B, wired with some very thin speaker cable, running about 25-30 feet to each speaker in a room adjacent to the one in which I have the receiver (supplying music to our sitting room).
With this setup, as I understand it, I think I should (A) keep the impedance selector on my receiver set at 8 ohms and (B) never run both sets of speakers simultaneously. I'm pretty sure A is right, but I'm not sure of B. Can anyone help? Has anyone seen this or similar stuff before?
Thanks,
Ben
Thanks,
Ben
