The Crown would work, but it's more expensive. The SI subs are rated at 600W RMS power handling, so the Crown might be a bit overkill at 775Wx2@2Ω. Then again, a little extra overhead never hurt anybody if you can afford the difference.
The driver you are looking at is a dual voice coil driver. That means the single driver has two pairs of + and - terminals. Remember your CSS kit, how there was a single speaker wire going from a - to a + pre-wired from the company? That's a series connection. Wiring two voice coils in series doubles the impedance rating, so wiring two 2Ω voice coils in series results in a 4Ω load. It's called "series" because the electrical path goes in series into -, out a + and into another -, then back out the final + and back to the amp. The signal path is twice as long as a single coil, so it's double the impedance.
The other type of connection, a parallel connection, means you are basically attaching both pairs of + and - on the driver to one pair of + and - on the amp. This halves the load rating. So wiring two 4Ω voice coils in parallel results in a 2Ω load. The amp has to drive twice the load of a single coil, so it's half the impedance.
And the lower the impedance, the more current is drawn. You don't want an impedance lower than the amp is rated to handle or it'll burn up.
There's probably an excellent graphic somewhere that illustrates this, but I'm too lazy to find it. Just look on
Google Images.
Now. To squeeze the most power out of whatever amp you choose, go with the lowest impedance rating that amp will support. For the iNuke and Crown amps, that's 2Ω per channel. The Europower is only 4Ω stable in stereo mode. But if you pair it with the correct load, a pair of 2Ω dual voice coil subs each wired in series within its own cabinet (netting 4Ω per channel), it'll provide wattage rivaling the other two amps.
Clear as mud?
So in summary, if you get the iNuke or Crown amp, go for a pair of the 4Ω version of the driver and plan to wire them in parallel (two runs of lamp cord from the cabinet terminal to the driver). If Europower, go with the 2Ω instead and wire them in series (one run of lamp cord from terminal to driver, and a single wire connecting the - of one voice coil to the + of the other). Whatever impedance you choose will either be doubled or halved, depending how you wire it.
