Hi, i'm pretty new to this forum, so here goes!
I have at the moment a acoustic solutions DS1233 surround sound system, connected to a Medion MD 41059 DVD player, and I'm trying to get a balanced surround sound... The set-up is as follows:
Basically,The TV is 10ft from my sofa, and the speakers are placed here:
the centre speaker is on top of the TV, 10 ft away from the sofa, the F/L F/R speakers are 10ft away from the sofa, with the woofer by the side of the TV, again, 10ft away from the sofa. The rear L and rear R speakers sit alongside the sofa, say about 2ft from me.
each speaker has a 5db output, apart from the woofer which has 4db.
Now, I can change the distance, the output, and the size of the speakers ( small/large) from the control panel on the DVD player, while I can change the volume of the centre, rear, and woofer, from the acoustic solutions 5.1 surround system.
Am I right to assume that you measure the distance of the speakers from where you are sitting to each speaker? or do you measure the distance from the DVD/TV to the speaker? Which is the best solution to set-up the speakers? is there anything on the web that might help?
Graham
