F
firefighterchri
The last post I did helped out alot thanks. I have another question regarding my new Yamaha RXV2500. I can't seem to get it to auto sense the audio it needs to be in such as DTS if I'm watching a movie with DTS. It seems to put it in THX all the time. Maybe I'm missing something and need to mess around with it more. Also the speakers I have are Polk Audio listed below and when I bought them the dealer said to put the low pass HZ on the back of the sub half way (90HZ). Yamaha says put it on max. Which is correct. I have all my speakers set to large with the crossover at 80HZ. Again, when I do the auto setup the receiver sets all the speakers to large and sets the crossover at 60HZ. It says that if I am using THX speakers (don't know if I am or not) set speakers to small or small X2 and set Xover to 80 HZ. If any can help me or if you have a similar setup such as speakers and/or receiver and know which way is the best setup to listen to movies and music. Thanks, I will be leaving for work and will get back with replies in the morning.
Polk Audio
Rti 12’s 9 (front)
Rti 4’s (rear surround)
Csi 5 (center)
PSW 505 (subwoofer)
50” Sony Grand Wega LCD projection
Yamaha RXV2500 receiver
Sony DVP725P DVD player
Dish network 811 HDTV receiver
Sony Playstation 2
Polk Audio
Rti 12’s 9 (front)
Csi 5 (center)
PSW 505 (subwoofer)
Sony Playstation 2
