my issue isnt the sound, it is amazing! it is the dialogue (voices from center channel) has no depth! they seem like there coming out of a can. with all of the awesome sound from the rest of the speakers it almost sounds like the voices dont belong!
could it be a setting in my speaker setup causing the big fronts or even the sub not adding to the smaller center channel to give it depth?
First of all, try turning Audyssey off to see how it sounds. If it sounds fine or at least much better, then you need to re-run Audyssey but follow their (Audyssey website, not Onkyo) instructions to the letter. If you did not follow instructions, then the results could conceivable be worse than without using Audyssey.
If it still sounds bad, then re- run Audyssey anyway following the instructions exactly, just in case and then make some some changes to the crossover settings after, such as follow:
- All speakers set to small
- L/R crossovers to 80 Hz
- Center to 150 Hz (it's freq response claim is 125Hz-23kHz, no +/- dB given)
- LPF set to 150 Hz
- Sub set to LFE
Before running Audyssey, disable all settings on the sub and set volume to around 11 to 12 noon position. It is also possible that you might have the center speaker connected out of phase with the others but normally Audyssey would pick that up and give you the warning.
