Did you position the mic exactly per Audyssey for all 8 positions?
You also have to disable all filters/adjustments on the sub so Audyssey has full control. Use the standard curve, not flat when done.-"
Yes, as I mentioned in my post that I read the audyssey setup guide and went thru couple of videos before starting the setup. I did the setup few times strictly by the book: 8 positions, all filters on sub disabled, turned off the heat in the house, no other ambient noise etc.
Audyssey doesn't seem to like my sub. It measures all the other speakers fairly accurately except the sub. It measures the sub at 15.6' where the actual distance is 12.5'. And sets the trim value for the sub way low at -8.
So, I reset the processer again yesterday and did a manual setup and here are my observations:
To get the same kind of bass(which is not very high) as my old Pioneer 43TX receiver I have to set the sub trim level in Denon at +9 w/sub dial @ 12 o'clock. Whereas with 43TX I had the the trim level at 0 w/sub dial @ 12 o'clock.
To reduce the brightness of my speakers I lowered the highest frequency setting(20khz) by 2 points in the manual eq.
Now everything sounds very similar as my old receiver but less brighter.
