I currently have 2 rf28 klipch floor speakers and I would like to get an affordable pair of bookshelf-speakers that have good wattage I don't need to have everything matching, but if it does that's great. I am looking to get a decent center speaker aswell. Lastly I am looking into having Dolby atmos and was seeing what is a good avr that isn't overly expensive that will do the trick. Currently looking for ideas so I can roughly see what the cost is for everything.
Thank you
By bookshelf speakers, do you mean for use as surrounds? If so, are we talking 5 channels, or 7?
I could not find a Klipsch "RF28" speaker! There is KF28's and there is R-28F, and RF-82, but no RF-28! Please double check the number! Thanks!
Can you describe the room these will go in? Height by Width by Depth and how far back the listening position is from the front speakers.
A budget is useful. If you don't want to pin it down, give us a range of how much you would like it to cost and the most you are willing to pay!
Your Klipsch are pretty efficient (never seen a Klipsch that wasn't), so that is good news - most any AVR would probably be okay to drive them unless you add less efficient speakers.
Do you plan on using a subwoofer?
