List of few reveivers worth looking at.
Thx Bob.
While the Denon 1609 deal sounds very tempting, I think I'll skip it since I don't want to deal with the multiple connections.
I went to a local Best Buy today -
The Pioneer sounded neat. Looks sleek too.
However, where can I get the 1018s for $300. I searched over the net and the least i found was $380.
The Yamaha 465 sounded pretty neat too and so did the HK 254. I was told the HK had the same HDMI/audio issue.
The search is on and hopefully I would be able to narrow down pretty soon. I heard the new Denon start-up line has a 5.1 with all bells and whistles.
Thanks
Well, the price of the Pioneer VSX-1018AH-K at $380 is not too bad (it was a bit cheaper before, prices always varied on-line).
Also the Onkyo TX-SR606 at around $319 or less is another very good alternative. It has Audyssey 2EQ and 4 HDMI inputs.
Another possible choice will be the Marantz SR4002, which is also in the $300-$350 price range. Also, last time I saw the Marantz SR6001, it was $350 at "accessories4less". That's a good reputable place for excellent deals to check.
And the Onkyo TX-SR705 ($440 refurb or less), is even a better deal. It has Audyssey MultEQ XT (which is a tremendous improvement over the 606), THX Select2, preouts for all channels (so you can add external amplifiers in the future if you wish so) and more power too.
Me, I will skip entirely the Denon AVR-1609 and also the Yamaha RX-V465.
For Denon, I will look more at the AVR-1909 or AVR-2309ci, but they cost more (they will drop in prices very shortly though).
And for Yamaha, I will look more into their last year models (better build and less money), like the RX-V663.
As for the Harman Kardon AVR 254, I can't say, I'm just not familiar enough with this model. And I personally try to stay away from HK. But that's just me.
OK, I hope this help you to look at the models that I consider worthwhile.
Cheers,
Bob
