Just got the Pioneer 578 a hooked up to my Denon 3805. A few questions to those who might have the same set up as i do..:
1)Any way to turn up the different speakers with the 5.1 set up? My Panasonic f-85 has this option. I also don't see a "test" feature like the Panny. I only see distance adjustments on the Pioneer.
2)When one wants to listen to DVD Audio or SACD, what are the proper settings on the Denon 3805? I assume you go to Digital input, select Denon Link, and change it to "ext in". I have a coaxial cable and an optical cable both hooked up so i can hear which one sounds better...that leads to my next question....
3)not meaning to start the coaxial vs optical debate again, but with my set up, what connection is better? I have a higher end $60 Monster coaxial and a lower end $30 Monster optical. I know..don't flame me for Monster..was my best option at the time. I don't seem to notice a difference, but the funny thing is, my girlfriend did
on first glance, I have to say this Pioneer doesn't appear to be an upgrade to my Panasonic F85. maybe a little in the picture department although it has no control to make it "blacker" like the Panny. DVD Audio is not as good as the Panny (or I am doing something wrong) as like I said, you can control distance and volume with each channel on the Panny. i have not tried a regular CD yet. Eagles Hell Freezes Over DTS DVD was excellent..I do not have a SACD as yet to try. I do however, really like the single disc and fast loading.
Thanks guys...
