My Pioneer Elite Receiver VSX-92TXH is on the way and I want to get my speaker setup thought out beforehand. Currently, a small Kenwood 8" sub is doing LFE duty (poorly) in conjunction with my Klipsch KLF20 towers. I have the opportunity to purchase select Klipsch, Martin Logan and DefTech subs at killer prices so my choices are limited to them. I also have the opportunity to demo all subs by these manufacturers.
My audio needs are 60/40 music and TV/Movies. The listening room is large at about 3300sq ft and is open at almost all ends to a foyer, dining nook, sliding glass doors and a hallway. Ceilings are 8ft and sub placement will be at the right side of the front stage in the corner of the room.
The KLF fronts are fairly efficient and are rated at 34 Hz-20 KHz +-3db. The center is a matching KLF-C7 and the rears are going to be replaced.
The subs I am currently considering:
Klipsch Reference RW-12D ( I can get this for $279 and is the lowest priced of the bunch by far!!)
DefTech Supercube II, III
Martin Logan Abyss
(SVS PB10-NSD and HSU STF-2, VTF-1 will also be considered before my final purchase is made. I already am aware of the outstanding performance of these subs.)
Please advise me which subs you would recommend out of these listed and why. I am eager to hear your comments! Thanks in advance for any help and advice offered.
