Help with my Yamaha RXV2400
Ablative
So I got a Yamaha RXV2400 (it had a great review here). i've spent the last week trying to get it to work.
My problem is that I cannot get sound to come out to my speakers. :mad:
I should mention the only exception is that the auto setup puts out test signals through the front speakers and the subwoofer.
I can get sound through the preouts and the record/zone2 outs but not through the powered channels.
Any help you could give would be appreciated
Thanks
gene
gene
Audioholics Master Chief
Administrator
Check in the manual set-up to make sure you have all of the other speakers turned on. Since I no longer have the review sample, I can't tell you the exact key presses. Perhaps other owners here can help.
I suspect you don't have the other speakers configured.
Amico
Guest
Pioneer Elite VSX-53TX vs Yamaha RXV1300
Hi All,
I am planning to buy a receiver which has all the features required for perfect sound quality. I am not too concerned about the watts 85- 100 is fine with me.
Can someone please tell me which one of the above two should I go for. Please feel free to suggest any other good ones too.
