Help with my Panasonic DVD S-77
  • Thread starter Thread starter jca93
jca93
9
0
0
Hampton Roads, VA
I have had a Panasonic S-77 for little over a year. I didn't have any problems with it until November when it would not play CDs. Took it to get repaired and since I got it back I can't get video when I play DVDs on my main system. It was and is currently connected to a Pioneer VSX-74 reciever (I have checked that all cables are seated properly and the correct input assignments were made) via component and Toslink cables. I have plugged it directly into two TVs using component cables and the player worked perfectly. This leads me to believe my receiver is to blame, but if I plug in my Panasonic DVD/HDD to the same connections it works just fine. I'm guessing either the DVD player or receiver had some settings change that are keeping the picture from displaying. I'm checking the owner's manuals, but if any of you have some suggestions, I'm open. Thanks in advance!
Jason
Pioneer Elite VSX-74
Carver TFM-25
Panasonic DVD S-77
Panasonic DMR EH-50
HR 20 HD Satellite DVR
Sony SLV-N88 VHS
Philips 42" FP9630 Plasma
Onkyo TA-RW 505 Dual Tape deck
Def Tech UIW 94s (fronts and center)
Def Tech UIW 83s (rears and surrounds)
Velodyne DD-12 Subwoofer
