Help with Marantz SR4002...
I
Inertia
Help with LPF/HPF with Marantz SR4002...
I recently got a Marantz SR4002. I have a 3.1 setup right now with it. My problem is you can set the center and fronts to "small" or "large" but the LPF/HPF only goes from 80hz to 180hz.... I want to cross my center at 50 or 60hz because it can handle it and supposedly the center I have is awesome around 50 to 80hz. But I am guessing if i put the center as "large" it will play full band which isn't good. Can anyone help me figure this out? Also since it is a LPF/HPF does that control the sub as well? I am really confused....
If anyone is wondering... this is the center channel I have:
http://www.geocities.com/cc00541/Statements_Center_Channel.html
Lordoftherings
Lordoftherings
Did you consider upgrading your receiver? Like the Marantz SR6003, for example?
Bob
