I am new to this forum and I dont know a lot about audio systems. That said, I am trying to put together my first home theater. Reading the posts in this forum has been extremely helpful.
I am finishing my basement and one room is the HT room. The room is approximately 17x17. I have a gas fireplace in the center of one wall and will be putting a 52" Samsung LCD over the firstplace. The fireplace and mantel is 24" in depth and thus the TV will 24" into the room as well. The listening point will be a couch directly facing the TV approx 13-15 feet away.
The ceiling is 8ft and will be a suspended ceiling with 2x2 tiles (the 8ft includes the suspended ceiling as the current open ceiling is approx 8'6" and the drop will be about 5" or so).
I plan on installing in-ceiling speakers (I understand that is not ideal for sound although that is the "compromise" I arranged to have my man cave).
I have read all the posts I can find in this forum regarding in-ceiling speakers (again, extremely helpful) and I still have the following questions:
1. First question, 5.1 or 7.1? Is my room size too small for 7.1? I was thinking of setting up a 5.1 first and them perhaps upgrading to 7.1 in the future. I understand that I wouldnt have to move any of my 5.1 in ceiling speakers for the 7.1 setup but merely add to speakers to the sides of the listening area.
2. My budget is approx $1,500 for speakers, receiver and subwoofer. I have been researching the speaker issue (I havent really looked at receivers and subwoofers yet) and I think I have it narrowed down to Speakercraft, Niles and Boston Acoustics (although I think BA may be out of my price range).
I was thinking 7" speakers as 8" speakers would be too big for the space..agree?
Also, as stated above I am not very sophisticated when it come to audio issues so a system that merely sounds good is fine with me...based on that I was thinking low end speakers from a good speaker company. Also, I would use the speakers almost exclusively for a home theater rather than music.
Regarding Niles, I was thinking the lower end speakers (CM730DS for LR, CM 730DSc and CM730DSfx). I think that will cost approx $800. Moving up to the CM750s would cost approx $1,220).
Speakercraft I was thinking of the AIM7 Twos or Threes whichever I could find in my price range (use the same speaker for all 5 loudspeakers).
3. Is there any problem with installing in-ceiling speakers in a drop ceiling? I havent found any questions regarding this issue in the forum.
4. Do I need back boxes for the speakers and does the drop ceiling issue create more of a need for back boxes?
My ceiling is insulated with mineral wool which I understand is a decent sound proofing material and the drop ceiling will hang down another five inches or so (because of pipes etc) below the rafters so I have quite a bit of room to install the speakers considering the space between the rafters plus the additional 5 inches.
Sorry for the length of the email and I certainly appreciate any additional information you can provide.
Thanks in advance,
AMyles.
