Ok, here is the gear in use: Amps are Carver Silver Seven-T Mono-Blocks, Preamp is Carver C-27, Speakers are Infinity SM-150.
Problem: Fire up the system and huge ground hum.
Steps taken so far: Disconnect all inputs to preamp (CD and TV) and the hum is still there. I ran a ground wire from the ground post on the preamp directly to the power outlet center post, checked for continuity, and get the same thing.
There is no hum when I disconnect the signal cables from the preamp to the power amps (duh?), but I had to try.
the signal cables are not new and I can't vouch for them 100%, could they be the culprit?
Help me oh gods of audio!!
