jp8869 said:
			Huh............ could you put that in laymens terms.
 Free air resonance is 24HZ, the manufacturer is shooting for an enclosure where the resonance is higher, almost double in a sealed enclosure (Fc). The Qts says that this speaker can be used for either sealed box or ported, not unusual, one size fits all manufacturing. Just looking at the published specs and what the manufacturer recommends for enclosures leads me to believe that they designed the speaker to work in a loaded enviroment, not Cheech and Chong but close.
Think of it this way, the strength of the coil/magnet system can out do the mechanical dampening of the speaker in an open air structure, this is your excursion. Now I'm sure there are tons of internet articles that will disprove what I'm saying, so be it. But I did this stuff 30+ years ago and just now have decided to get back into it and see the same things today that was present back then (I love the speaker wire stuff).
The fact is that a speaker is nothing more than a electro/mechanical device to move air, how it moves that air is strongly dependent its enviroment. Free air resonance (Fs) tells me where the mechanical properties of the speaker are at, but they give no indication of what the speaker is really doing there. For a manufacturer to suggest going up with box tuning, tells me that in order to get the Fs they publish, they have allowed the speaker to be very limber vs the weight and displacement of the cone and they are wanting you to keep the speaker in it's operating range to avoid damage.
Back in my time, trying to go to 24HZ was never heard of, what was the point, no music played there. Today, the trend is to be able to say "I'm tuned to 20HZ". The manufacturers know this and will play on it as far as they can, even to the point of decieving you into to hoping your 12" mega dollar speaker will be the king of all.
The key here will be to test your speaker at the ranges you want it to play. MDF is cheap, build a box and see how it does. Without a curve on the speaker, I would guess that the impedance rises very, very sharply at or near Fs, thus the ability to play down low in a car.
JMHO
