I need help with the crossover in my home theather. I have a SONY STR-DE875 receiver and Wharfedale +60 Speakers http://www.iagamerica.com/wharfedale/moviestar60.htm), but I change the central speaker for a The WH-2 system speaker
http://www.iagamerica.com/wharfedale/wh2.htm.
The problem is that when I read the articles in the forums, I can configure most of the options you talk about. My big problem is crossover. there is no crossover configuration in my receiver, just one in the sub. I get a decent sound with It but no a clear sound.
This is how my receiver is ( I just reset the option so this is the standar config and I put the min level and the max posible):
EQ:
Front bass: 0dB (-10 to +6)
250Hz ( 99Hz to 1.0KHz)
Front mid: 0db (-10 to +6)
1.0KHz (198hz to 10.0 KHz)
Front treeble: 0dB (-10 to +6)
2.5 KHz (1.o KHz to 10KHz)
Same for Center
Surround Bass: 0dB
250Hz
SUrround Tre: 0dB
2.5 KHz
LEVEL:
Front. Surround, center S.woofer: odB ( standar settings) (-10 to´+6)
LFE MIX XXX db: 0dB
D.Range COMP. : MAX
I really need your help
Thanks
