I use the surround back channels as a second stereo speaker zone in my house. My receiver allows the SBs to be used in this way.
Recently my wife asked if the secone zone sound level could be lowered a bit relative to the downstairs zone. (my second zone is upstairs).
I thought that should be pretty simple, but as I get into the level adjusting menus I find that I cannot access this pair of speakers in the same way I can get to any of the others in my primary 5.1 congif. In the menu it will just have the SBs marked N/A. I read the whole manual. Can't find the solution.
Anyone?
Also while I am at it, I just added an extra sub to the setup. basically just daisy chained it to the 1st sub (if that is the correct terminology, I'm just getting back in the audio game). I have a couple of Klipshe RW12s. It sounded good right off the bat just by cableing up and plugging in, not louder just fuller and thicker, plus I get a giggle out looking at em sittin there side by side. Do you think I need to go back and do any auto speaker setup stuff? I need to get back into reading the forum, so I will understand if you guys just say 'go dig into to the forums and articles'. thanks.
