help with cables pls
V
vanislejc
Hi there, I am in the middle of buying a new tv looking to spend around 1000cdn...Looking at a 34 inch widescreen tube toshiba, anyone have any thoughts?? My real concern is with the cables...I wont be hooking up hd right away. I will be hooking up a dvd player and vcr to my pioneer vsx-1015tx. How should i go about it?? i am on a budget mind you.. i was thinking component video from dvd to tv or s video. and coaxial from dvd to amp? and rcas from vcr to tv...i also want to hook my computer up to my amp what are the best cables for doing that it is about 30 feet away.. any information and input would really help me out thanks
Does that VCR have S-video out? If yes, hook it and the DVD to the amp with svideo, then svideo to TV, for now.
If no, then as you posted. No need for expensive cables. If you go component, 3 video cables will do, even rg6 types.
You could use RCA terminated cable TV coax from your computer to the amp. That should be inexpensive enough.
