Help with bypassing sub plate amps
Liquid Air
Liquid Air
Need help from some of you clever sound guys out here. My House was recently struck by lightning which fried out a lot of my audio equipment including the plate amps of both my Subs and a few various other components. So a friend suggested to bypass both plate amps and connect my Martin Logan and Klipsch RT-12D via 10 gage speaker wire and connect them to an external amplifier which I have a crown 2,500 Watt amplifier. However the signal is not strong enough so I have them run with RCA cables to my separate tube phono preamp to boost the signal. The work, trouble is when I turn it up too loud there is a popping sound like the voice coil is bottoming out and certain bass tones or at medium too loud volume. How can I avoid this and is this the best possible way of hooking things up without replacing the Subs? Thanks ion advance..
If your sub's plate amps were fried but not your drivers you could easily use another amp. How you bypass the plate amp could be key, how did you do that?
You first job and expenditure is to get your house up to NEC 24 electrical codes to very substantially reduce the risk of this happening again. So this means SPD-1 surge protections at the entry of electrical service to your home. Then you need SPD-2 surge protection at every panel.
We need more information about those subs. Are they ported or sealed? If they are sealed then you need original plate amp replacements. If you want to use an external amp then you need to disconnect the sub driver from the plate amp, and connect the sub driver directly to the speaker terminals of your power amp. The plate amp needs to be put back in, or the hole where is was closed up.
Now you do need to check the impedance of the sub driver, as some subs have drivers of unusual impedances.
The last issue is that the drivers may very well have been damaged in the lightning strike, and may well have damaged voice coils with shorted wire turns. So you need to check the DC resistances of the woofers VCs. The DC resistance is usually about 60% of the driver impedance at least, and anything less indicates a partially fried VC. The DC resistance can be as high as 90% of the impedance, but this is unusual. It generally is very close to 60%. The chance of the driver being fried is high after an event like this.
