Hi all,
I've moved into a new apartment have a new setup with my record player where, out of necessity, across the room from my receiver and speakers.
I've got a Music Hall MMF-5 and a Rotel receiver, with B&W speakers. I've run about 25 feet of extension RCA cords to connect the record player to the receiver. The receiver and record player are plugged into different outlets, completely across the room from eachother.
When I turn the receiver to the phono input, it generates a loud buzzing, regardless of whether the record player is on or not. No other input for the receiver has any buzzing and other things work fine on it.
The MMF-5 has a ground cable (a little horseshoe-shaped metal thing) that I used to have screwed into the ground screw on the back of the Rotel, but now I can't because of the distance. I assume that is what is causing the buzzing.
I tried to fashion a "ground extension" cable by using speaker wire to connect the ground to the receiver, but it did not fix the problem at all.
Can anyone help? Thanks very much in advance.
