Hi guys,
I did a quick search in the forums and didn't see anything specifically pertaining to this issue, but I apologize in advance if you've heard this 1000 times. Also I'm pretty new to Hi-fi so go easy on me
I have an older Sansui AU-11000 integrated amplifier (120 or 150 WPC @ 8ohm, I don't have the manual and I've seen this amp rated for both) supplying 2 Polk Audio R50's. It's nothing crazy, I mostly setup this system to get back into my vinyl collection. The R50's are 90db efficient and rated @ 150 Watts RMS with an 8ohm impedance.
http://www.polkaudio.com/homeaudio/specs/r50/
The problem I'm experiencing is that at a high volume (maybe 8/10) I experience a very noticable distortion in the music (like you were talking into fan kind of noise). Obviously this is a bad thing and immediately turned the volume down. Is this a classic case of the amp "clipping"/not being able to power the speakers efficiently? If so would a more powerful amp be a solution so I wouldn't have to tax the amplifier so hard to get the same result? If this amp does infact output 120WPC then I could probably use some power in reserve.
Or could this be my speakers not being able to handle the volume. I know they aren't the BEST speakers but it was what I could afford at the time. You could definitly tell the distortion was coming from the tweeter/midrange set of speakers. The bottom end seemed to be holding up fine.
Thanks in advance.
