Help w/ rear speaker placement - Diagram attached
E
el.dustino
Hello all,
We're about to move into our new house, and need to figure out rear speaker placement before the hardwood floors go in. I have Paradigm Studio 60 v1's in front, a Harman Kardon AVR 520, and am thinking about putting ADP's in the rear.
I've read that rear speakers should be placed to the sides of the listener, but due to the room configuration, I'd much rather put them near the rear wall to get them out of the way. Will the ADP's or another rear speaker perform well in this placement? Check out the diagram to check out where I'd like to put them. Any thoughts welcome.
Note that the line next to the couch is not a wall, but a step into the dining area. So my questions are:
- Is the Paradigm ADP such as the ADP-170 a good choice for this setup?
- Does the placement noted in the diagram work?
TIA!,
Dustin
L
Leprkon
If you are setting up a 5.1 system (maybe you said and I missed it), then you definitely want the speakers behind you. This gives you the sense of things passng over your head (like airplane flyovers and magic spells)
If you are setting up a 7.1, then the surround back should be behind you, and the surrounds should be to the sides.
The rear speakers are not super-critical unless you are doing SACD or DVD-audio. If you are running mostly movies, even a reasonably cheap set of outdoor speakers will provide decent sound.
The rears only get mid- and higher frequencies, which are the sounds best detected for movement. The human ear does not locate lower tones well (you'll hear the term "omnidirectional" alot), so most receivers do not send the lower tone to the rear speakers. Since you don't need a big woofer to support those lower tones, most any speaker will do for the back.
You may have heard about "timbre matching". This is very important for the front three speakers, but the spacing between front and rear make this alot less important.
If you do SACD or DVD-audio, the best set-up is supposed to be all the same speaker all the way around.
The long answer to your short question is those speakers and placements should work very well with the system you have.:)
E
el.dustino
It sounds like I could just use my Bose cubes in the rear, but I'm going to upgrade anyway. Thanks for your input.
~Dustin
E
el.dustino
Just one more thing. Should the rear speakers be inline w/ the fronts? Thats assuming I get the ADP's, if that matters.
TIA
