we've been in our new house for about three years now - so far, I haven't been able to dial-in our living room (our main tv and music listening area) quite the way I wanted. It's a large, open concept space that includes the kitchen behind, a two-story fireplace area with floor to ceiling windows to the left, and a large patio door to the right. I've attached a floor plan to help you all visualize the space - "x" marks roughly where the tv is installed.
The width of the entire space, including the fireplace area, is about 28ft, and from the tv to the back wall of the kitchen is about 30ft. The main couch is about 12ft' from the tv and 11ft from speakers, which are about 9' apart, and can be pulled out 1ft from the wall (max).
We have a Sony 75" 950H.. it's perfect for the space. The issue has always been the sound. It's obviously a challenging space, but I want it to be better for both music and home theatre. The room does have three large rugs scattered about, including between the mains and couch, and four plush couches.
Current gear
Amp - Denon 3600h
Mains - Revel concerta f36
Centre - Energy C-C1
Sub - Paradigm PS-1000
No surrounds, no Atmos.
Sources are mainly Spotify Connect streaming through the Denon and sometimes a Technics 1200 for vinyl. Video source is streaming services via the Sony.
So... My question, if you've been patient enough to read this far, is what do I prioritize in order to improve this setup for both music and theatre? We listen to music a lot, usually while cooking, moving around the room, eating, dancing, etc. Focused listening might happen about once a week. Right now it sounds...ok. it gets pretty loud and music sounds pretty clear throughout the living areas - but I have to believe it could be better.
For theatre, I notice sub integration isn't great, dialogue could be much clearer, and I really miss having surround speakers, and would also like to have Atmos. Movies don't sound big, clear or immersive enough.
Questions
1. Where can I install rears/surrounds? I thought about doing one pair of Atmos speakers just ahead of the couch, and one set of rear surrounds, also in the ceiling, behind the couch. I recognize ceiling rear speakers are not ideal, but I can't figure out where else to put them, unless they go on top of the kitchen cabinets, about 16ft behind the listening position and about 8.5ft off the ground. Wiring them there will be a pain but I could probably manage it. But would it really sound better than putting them in the ceiling behind the couch? Are there any location options I'm not seeing?
2. Upgrade the Main speakers? - I like the Revels... but I have an upgrade itch. What could I get that would better suit the room and sound great for all kinds of music and HT? Note I have a pair of ohm Walsh 4s that I want to try in this main system, but they sound "off" and tinny in this room. I suspect the foam surrounds are failing and plan to take them to Ohm for a check up on my next trip to NYC. I also think they need way more power. They are currently in my bedroom with an HK3490 where they sound better, but still not quite right.
3. Is it power? Should I add a 2-channel power amp, like hypex ncore, to really bring the mains to life in this large space? This would likely help the Ohms, if they end up moving to the main room, and it might help any mains you guys recommend, or even the current Revels.
4. Is it the sub? Current sub is an older, mediocre sub, quite boomy and not up to current standards, I don't think. But maybe that's due to my challenging room. Should I focus here first, maybe add something like two RSL speed woofers with wireless adaptors?
5. Is it the centre channel? It's older and was part of my first HT setup - was great in a small apartment in 2005, but perhaps not up to snuff in current use.
6. Is it something else? Open to ideas. Room treatments will be next to impossible, though perhaps something discreet just behind the main towers could be possible.
Thanks for reading, and looking forward to your advice.
