Suggestions...
Hi JasinS;
My first suggestion for you would be to determine what it is you would like to improve in your listening environment. For example:
- Are you looking to improve the overall power output of the system (e.g. louder)?
- Is it the tonal qualities of the system you're looking to improve (e.g., too dull sounding, dialog's weak, separation is poor, highs too sharp, etc.)?
- Do aesthetics play a factor (eg. current setup unattractive, too large for listening environment, speaker finishes do not match, etc.)?
Determining which of these (if any) are more important to you might help you in narrowing down what needs upgrading first in your system. In the same vein as Nick's post, my first suggestion, not knowing the answers to the questions I posed, would be first to consider upgrading you mains and center as your listening preference is predominantly TV and movies. The front soundstage is where 70% or more of the soundtrack for both mediums will be carried. I mention the center channel as well as the mains as maintaining timbre matching and the ability to pan sound from left to right in the front soundstage is critical for most dialog/ front soundstage driven material. While room characteristics can play a big role in the listening environment (which I won't even get into here), quality speakers can also have a large impact on the listening material.
Based on your budget, I would consider five matching bookshelf speakers paired with a quality sub to make the most notable impact in your listening environment. While the DCM TB-1 may suffice as a sub, you can likely upgrade this for a reasonable amount that would make a noticeable impact. For example (prices before shipping):
- 2 pair of AV123's X-Series x-ls bookshelf loudspeakers at $219/pair ($438 before shipping)
- 1 x-cs Center/Main/Surround loudspeaker for $139
5 speaker total = $577 b/shipping, approx. $700 w/shipping
There's a review on the x-ls bookhshelfs from AH
here.
or
5 speaker set system from SVS for $599 (approx. $50 for shipping) for a total of approx. $650 w/shipping. There's a review on the this full system (including the SVS PB-10 sub)
here.
1 Athena Audition AS-P4000 Subwoofer for approx. $200 shipped
This would provide a solid 5.1, timbre matched speaker system with modest aesthetics and give you decent low-end for a relatively reasonable price. This setup, coupled with your HK AVR-130 shoudl do well in a small to medium-sized room. While the 130 could stand an upgrade, I believe you'd get more bang for your buck by upgrading your speakers and sub while retaining the receiver. This will also allow you to upgrade your receiver at a later time when funds allow to either provide you with more power or improve on the quality of the receiver's sound and feature set. While speaker preference can vary greatly with each listener, The neutral characteristics of the x-ls bookshelfs provide some of the best sounding, well built speakers for the money available today. The SVS SBS-01 system also has proved to be a relatively inexpensive speaker system that performs quite well with movie soundtracks, giving way only slightly to the x-ls system in the musicality department.
If you'd prefer for the time being to spend less and only upgrade the front soundstage (L/C/R) and subwoofer for now, this might also be a consideration for you. There are several other options than the ones I'd mentioned, but hopefully, these will provide you with some guidance as to what might be your first steps in the 'upgrade' process.
Good luck in your search, Jasin, have fun w/it!
-TD
