Help...TV stand for Mits WD-62725 hard to find
Methodical
Hello all. I have a 62" Mitsubishi DLP TV (# WD-62725). I've been searching and searching for the matching tv stand. It seems a matching tv stand for this tv never existed although I know for a fact there is one because my coworker has the same tv and stand. I searched Mitsubishi's archive database - nothing like it never existed. I even called Mitsubishi's dealers and was told to call Mitsubishi, which I did - again nothing. Mitsubishi does not have anything in their "database" for this particular tv (was on hold for like 28 minutes and transferred to the "next level of service" which they stated the hold time would be 93 minutes - 93 minutes damn. I submitted an email - again nothing. They have no clue. :mad:
But I think the tv base for the WD-62525 is compatible with my tv.
1. Can anyone vouch that the WD-62525's tv stand (MB-62527) is compatible to use with my tv? If so, can you direct to where I can purchase one.
2. What color are these tv stands? Can't tell if they are black, grey or what
3. If not compatible, can anyone tell me which stand can be used for my tv and where I can get the tv stand?
Methodical
AVRat said:
According to the manual, the MB-62525 is the stand. Can't vouch for their rep, but try here: http://audioexcellence.com/index.asp?PageAction=PRODSEARCH&txtSearch=Mitsubishi+MB-62525+&btnSearch=GO&Page=1
You should also try a local Mitsubishi dealer.
Thanks for the info. I will check them out. Oh, I did call the local dealers and even Mitsubishi. They did not even know a part number for the stand. One dealer rep even stated that he was not familiar with the tv:rolleyes: .
agarwalro
agarwalro
I assume the whole point is to get the matching stand. If not there are a host of options out there. Here is one for instance, Stand
Methodical
Correct. I've given up on trying to get the matching stand -besides it's silver. I've been researching that sight for a good part of the day. I like that stand but I don't want a silver stand I want a black stand. I found one that looks good at Best Buy. I will check it out tonight. Just want to make sure it can accomodate my center channel but I still may get it and just put the center channel over the tv or on the back wall.
