help - strange behavior!!
tmurnin
tmurnin
So the other night I sat down to watch a movie, popped in a BluRay and started watching. 10 minutes into it the video starts cutting out randomly. Audio still seems mostly ok but not great, either. So, I think, great. Bad disc. Took a look and didn't see any visible damage to the disc, but popped in a different movie to check. Same thing happens. So, I check the cable (HDMI) connection on both player and AVR, no issues. Now I'm thinking the BluRay player (Panasonic BDT220 - about 2 years old) has crapped out, so down to BestBuy for a new one. Got the Panny BDT230, plugged it in, did the recommended firmware upgrade, and start to watch. Same problem. Changed out the HDMI cable. Same problem. Now I move the input to a different port on the AVR (one that has worked fine with AppleTV plugged into it before), same problem. I have no idea now what to do. I have the following equipment:
Anthem MRX-700 AVR
Panasonic BDT230 Blu-Ray
Samsung Plasma TV (can't remember model number)
The only thing I'm considering is whether there could be a problem with this specific firmware version on the Panny BluRay given that it happened on both models. Seems a little strange but no other real ideas right now. I guess I could go and buy a Sony or Samsung BluRay player to verify that, but I'd rather not spend the $$ if I don't have to. Alternatively, I guess there could be an issue with the Anthem AVR and BluRay signal, but I don't know why that would just pop up now after 2 months without any issues before and on multiple ports.
Any other thoughts? I've tried multiple discs, both BluRay and DVD format, and had the same problems on all of them.
agarwalro
agarwalro
Try unplugging the receiver's power for 5 minutes.
tmurnin
tmurnin
So I believe I have narrowed this down to a firmware update issue in the Panny Blu-Ray players. I borrowed a neighbor's Samsung player and no issues whatsoever for the past week. Wonder if anyone else has encountered issues with the latest firmware update in the Panasonic?
