Help - Speaker Config. on Onkyo 701
rbcody
<font color='#000000'>Newbie here. &nbsp;Just setting up my new Onkyo TX-SR701. &nbsp;Very simple config. right now. &nbsp;Just front left and right speakers and nothing else attached. &nbsp;But when i go into speaker config. under setup, Front left/right does not even show up as an option, whereas the manual definitely shows it as scrollable item no. 2 after subwoofer. &nbsp;
Can anyone help me? &nbsp;Thanks.</font>
G
Guest
Guest
<font color='#000000'>If the subwoofer is set to &quot;NO&quot; then the TX-SR701 will automatically set the front L/R speakers to &quot;Large.&quot; You will not be able to change it to &quot;Small&quot; or &quot;None.&quot; &nbsp;You should still see choices a through f on the screen though.</font>
