Help Sony STRDG720 and PS3
RoninStang
Hey,
I have a STRDG720 hooked up to a ps3 and a Samsung LCD using hdmi through the receiver.
What should I have the audio settings on the PS3 set too under audio output settings? PS3™ | Audio Output Settings
Do I need to check all the Linear PCM Channels such as 5.1 ch 48khz, 7.1 ch 48hz and so on...
Or can I just leave the two 2 chn (44.1 and 48) linear pcm channels checked, and the Dobly Digital 5.1ch and DTS 5.1 ch checked and still get all the new codecs played by the ps3 (TrueHD,etc...) and sent through the receiver when its sets to A.F.D auto?
The reason im asking it because when all the boxes are checked I'm unable to pick any other surround settings, when I hit Afd auto on the remote I get the message on the receiver display saying "NOT USED" and grayed out. I use my ps3 as a media center and like to have music on multispeaker and some divx and dvd movies on other surround settings. With all the boxes checked I'm unable to change anything as noted.
Thanks for any help
And if I can't change it will the STRDG820 do what I want since in can decode the newer codecs itself?
ratm
I may be wrong, but I dont think you can get decoding with the sony's until you hit the 920.
