<font color='#000000'>Believe it or not, you generally don't want to use the equalizer unless you have a dinstinct problem in your room that you know you need to correct for.
The general rule is to bypass the EQ when possible (if the receiver lets you) or set all the EQ or tone settings to 0 (neutral) positions.
Then sit back and listen to your speakers.
You may be tempted to raise the bass or treble frequencies to 'accentuate' them, but I would suggest that doing so would result in muddying up your sound rather than actually helping it (you will most likely lose detail and clarity). And once you turn up the bass you may feel like you're "removing" it when you go back to neutral. If you want more punch or low end, hang loose until you can afford a subwoofer that is designed to fill in that area of sound.
You certainly won't do any harm playing with the EQ, but I don't generally recommend it due to the "mud" factor.</font>
