Jmck
Hey, I have a paradigm system and need some help setting it up correctly.
I have 4 monitor 9's as fronts and surrounds. 2 subs, a paradigm 3200 and a paradigm 3400 (not sure more than that with the subs)
the amp is a denon 3311 because he said that would go great with it.
This is what my room looks like with all the blue being the speakers and where they are sitting with the sub to my right.
I think one thing I should do is put the surrounds on stands? a bit higher?
but im also not sure on my sub placement for a room of this size and shape.
Ive been trying to get everything setup, ive used audyssey but have reset my channel power for the subs because it put it on -12 assuming the subs were ****.
I have 2 sub filters to remove the big droning banging sounds. Ive been doing anything I can to also match the sub frequency's but im fairly lost with that. The upper sub frequency is as low as possible and the top one is just above half. The system sounds great, but I KNOW it can sound better.
I have a new sony 3D TV 55 inch connected with a ps3 and sound docks connected to it with everything running through the amp. I am about to redo Audysset because ive moved speakers and subs a bit and I know it needs to recalculate.
I also got told to change my LFE to -10DB from 0 but the settings arent showing up in the amp when I play a surround sound movie.
So any advice would be greatly appreciated
