jbrillo
jbrillo
I'm not sure which forum to post this in as I have no idea which component is causing the problem. Here's what's going on. I've got a brand new Sony upconverting DVD player(model# DVP-NS700H). It's connected via HDMI to a Yamaha RX-V661 and out to a Westinghouse TX-42F430S(42" LCD) via HDMI. Now, when I had the DVD player set to output 1080p, the picture & audio kept cutting in and out. The screen would kinda blink for a second then come back on. The best I could figure out to alleviate this problem was to set the DVD player to output in 1080i mode. The picture finally quit blinking. So what gives? Why can't I use 1080p mode when all of my equipment is supposedly 1080p capable???? Any help is much appreciated.
markw
As far as I know, the only products currently capable of producing a 1080p signal are Blu-ray and HD-DVD players.
markw
Try hooking DVD player right to the TV and bypass the Yamaha.
I wonder if it could be different versions of HDMI?
According to the Sony web site it does up-convert to 1080p?
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&productId=8198552921665393601&langId=-1
I agree with the suggestion in your first sentence and believe that your postulation in your second is quite possible.
As for it upconverting to 1080p, I must ask why this is a priority. First off,the only source of "true" 1080p viewing is the two previously mentioned HD video formats, and these need no upconversion. Standard DVd's are still 480 and always will be.
All Televisions "upconvert" internally into it's best native resolution. By forcing this issue in upstream components presupposes that they can do a better job than the TV. This isn't always the case and, with HDMI "standards" in such flux, it seems that it may actually create more problems than it solves.
And, while the DVD player may upconvert the 480 of a standard DVD to output 1080p at the HDMI output (I didn't look), it won't really "improve" the picture significantly. The TV might do a better job and that's why your first sentence makes so much sense.
Additionally, if the DVD player (at 1080p) works correctly when connected to the TV, it will narrow down a sitiation with the reeiver. If not, it will point to a situation with either the DVD player or the TV itself. That can become trickier. but, one step at a time.
jbrillo
jbrillo
Thank you gentlemen for the replies. I will try to do more testing later this evening when I have a chance. I appreciate all the info.
jason99999
someone help!!
I recently purchased a PILOT 254 receiver from a flea market.I have been trying to find out info and specs on this receiver.I cant find anything anywhere.I basically would like to know the value in fair condition and perfect working order.
Im requesting someone who can guide me in the right direction for this issue.
thanks jay
