hello
so i got the speakers.
what i want, is to play cd's and listen to the speakers.
on the speakers, it says " Inkel 3 Way Speaker System ".
can i just buy a cd player, and connect the speakers to the cd player?
or do i need something in between?
the wires at the back are two seperate negative and positive wires connected together. ( i think they're made from copper ).
so im going to get some banana plugs and connect them.
so is that it? is that all i need to be able to play cd's?
I apoligise if you dont get what i mean, im new here, and i dont know anything at all about audio.
