Ramy
Hey guys, I'm new here.
I need help finding a decent system. I don't know much about this stuff, so I need your help.
Couple months ago my dad came home with a 5.1 system. So I took it and set it up in my room. But it was one of those White Van Scam Speakers, so yeah they weren't that great... (lol :p)
Do you guys know any good 5.1 systems, doesn't need to be that special, since its going to be in my bedroom :p
I have my computer connected to my TV. And the speakers connected to this soundcard:
soundblaster.com/products/product.asp?category=1&subcategory=208&product=14066&nav=1
Any help appreciated, thanks
agarwalro
agarwalro
What's your budget?
You will need a receiver, maybe something from Yamaha, Denon, Onkyo, Pioneer, HK, etc. and speakers, maybe something from Axiom, SVS, AV123, etc.
Ramy
Thanks for the reply.
What do you think the price range is for something just for a bedroom (thats not a crappy system )
Let me know, so I dont say something stupid. lol :p
I'll look for some of the brands you mentioned soon
Ramy
Ok thanks guys. I'll buy in a couple months. Probably the max i can go is 1k (less would be better tho haha)
If you guys have more suggestions, plz post
Ramy
A nub question (sry if its really dumb lol):
I have my soundcard where it has 3 audio Y-Cables...
So would this work?
pioneerelectronics.com/pio/pe/images/portal/cit_3442/424461672VSX-817-K_REAR_med.jpg
Or will I need something like:
pioneerelectronics.com/pio/pe/images/portal/cit_3442/316743263VSX-1016TXV_rear_med.jpg
Where it has 4 (white/red) inputs instead of max of 2 on the other one...
