Ok listened to a few and brought back 3 in my budget range to test in my system and a borrowed stereo amp
im writing this in the small hours so forgive me if it becomes non sensical ill rewrite tom if necessary
Remember im no expert audiophile
one product had usb to toslink spdiff converter ability as well as a dac
one had usb to rca spdif converter ability as well as a dac
The converter side of things didnt make much diff to the sound card out to avr optical. Might be a subtle one but not one i could pick out without really trying and i didnt spend much more time on that side of things.
Only advantage of a pure converter in my situation would be no need for sound card and ability to link small format or tiny pcs eg raspberry pi (if compatible) digitally which is good.
Some with better ears may hear a diff as ive read people reviewing differences with converters in other forums.
Now onto testing the dacs side now to a stereo amp and also analogue to the avr amp and yes all 3 dacs had differences i could hear, and imo def 2 sounded better than my old soundcard toslink to avr for music
connected to the stereo amp sounded best which was to be expected, the avr did a good job of it though.
1 was def not as good as other two, 2nd was good, i liked it. 3rd was just a bit better but was a lot more money.
i picked the one that sounded best to me and best performance per cost and was impressed.
So i can get rid of my sound card to free up the space right in front of the graphics in my old shuttle sn25p. You'll know why i wanted to remove the sound card if u know the layout of that pc.
Plus i can mess with my raspberry pi as well.
Regarding what i think u wanted to know about, was it passing dts and DD 5.1 and hd audio? i forgot to ask but will be speaking to the guy after weekend to return the demos etc. If it was me and it was for films and it didnt matter about removing the sound card like in my situation i would just use the sound card optical or rca digital interface to avr dac, but i have a media player for that role.
Ive not really payed attention to HD audio as my avr amp doesnt support it.
but if hd audio is for films like dts and DD then i presume the converter is what u would need if all the correct stuff was passed through the usb converter to digital to avr. i dont know if it will be any better than a sound card or using your graphics hdmi audio out.
i think these things are aimed to music ill try n rem to ask.
The sep little usb dac works for me as
1 i plan i get a sep stereo amp so i need to hook my pc up to it and also as i want to mess with my raspberry pi
2 i can remove the sound card.
the ones i heard in the shop where ones around £150
audioengine d1
sidewinder one cant rem model now
hrt streamer 2+ older one hexagaonal shape ( had a new one but it was alot dearer as exdemo was on offer)
musiland 03
now onto 350- 375 ones
kingrex ud384
wryed for sound dac think it was the £400 model but only using its dac so it would be the same as the wyred 4 sound micro dac which is £350
i got to bring home a musiland 03 a hrt streamer 2 + hex shaped older one and a kingrex ud384
the kingrex sounded the best to me closely followed by the hrt ii + then the musiland 03
to me musiland was slightly vieled in the mids n treb.
the hrt sounded brighter n wider more alive n i liked it
the kingrex had that bit more detail was nicer but for me not worth the extra cost though u could tell it was the best one out of the 3 imo.
if i did want to go up into that range the guy was going to send me the wyred 4 sound micro dac to test as the demo was due back on mon and he would mail it up to me.
but i dont think ill be going into that range. In the shop it sounded like it might have been similar or a bit better than the kingrex ud384. The guys opinion is that it is a bit better but i need to hear it in my system to be sure and as im not going up in price i wont be hearing it.
ill have to see if i can post a link for his site in the uk as customer services was great n u get to test them in your system which i thought was great.
ok soz if that was all over the place its quite early here and im off to bed
