I would personally mount them on the side walls and back a little. Pretty much option A.
I have a distain for bi/dipoles, and also Dolby says to use monopoles. However, that is a slightly narrow room and some guys have used bipoles successfully(their claim, not mine) so bipoles could work for you. Dipoles should not be considered(for anything) with atmos because of the way they operate.
