U
Unregistered
Guest
Hi.
I am helping someone design an entertainment system. They have a Panasonic TH42PWD6UY plasma monitor, Denon AVR, Denan DVD. They want to have a surround sound home theatre but the speakers must be built into the walls and flush mounted. Does anyone have any suggestions? Thanks for the help.
Mantis
Yes,
Look into Polk LCi inwalls, SPeaker craft ,Sonance and Niles.
L
Leprkon
try the NHT L5's. they are wall-mounted and very thin (as opposed to in-wall) and match better visually to a wall-mounted plasma than the in-walls do (anybody besides me have flashbacks to 1st grade morning announcements from the principal over an in-wall speaker ??).
you can pick them up at accessories4less.com for about $ 500 each. A4L also sells the smaller L3's and the NHT and Canton inwalls should you insist on those.
