help on selecting an audio interface
Boerd
I need a audio interface with at least 4 spdif or optical or coaxial inputs and with at least 1 balanced outputs and that is 24 bit 192 Khz.
The reason: I have a bunch of electronics with spdif + coaxial + optical audio outputs like DirectTV Receiver, DVD player, SqueezeBox player and I want all these to go in some 192/24 dac and to get out a balanced audio signal that will enter in my preamp. My preamp has one balanced input that I intend to use so the audio interface I am looking for has to have a balanced analog output. Also they should use the same output if possible - I only have 1 balanced input in my preamp.
Am I making any sense here?
Anything you can recommend?
thanks.
