Help on projector screen?
David Gaudreau
David Gaudreau
Need help or DIY on building my own projector screen. What the best screen to build? to get the best picture.
Thanks
BMXTRIX
BMXTRIX
I made a 100" diagonal screen...
http://www.bmxtrix.com/gallery/photo/main_frames.cfm?folder1=theater&folder2=screen&imageName=theater_17&galName=Screen&image=theater/screen/theater_17.jpg
It worked very well. I followed, mostly, the instructions from AVS Forum for the Eldemar Screen: http://www.eldamar.net/house/ht/screenHowTo.html But, I used brackets in the corners and screwed everything tight - no glue.
The cross braces are a MUST as wood screens can bow over time unless properly supported in the center.
Final result of my screen...
