Help on Decision with Onkyo TX-SV525
bjsarma
Hi
I am planning to buy used Onkyo TX-SV525. I have Sony Speakers with 6Ohm Impedence. Will it be Ok if i connect 6 Ohm speakers to Onkyo that requires 8 Ohm. I am not sure of the minimum impedence Onka requires.
Appreciate your comments
Regards
Jags
marky
it should have no problem at lower to med volume but ill be careful with the lower line receivers.
MDS
The TX-SV525 should have no problem driving 6 Ohm speakers. I bought one new in 1996 and only a few years ago gave it to my brother-in-law for his garage system. It is still in mint condition and performing flawlessly. The 525 is the middle of the line for that series. You can get the manual for it on the Onkyo website under support->downloads.
That receiver is ProLogic only. Unless you are getting it really cheap, I would consider stepping up to a Dolby Digital receiver. You can get a TX-SR502 (which I also have) brand new for about $200 and change.
bjsarma
Thank you very much for the information. Now i am reconsidering my decision. You are correct it is only prologic.
