I'm new to the forum and this is my first. Apologies if this repeats anything from previous posts...
I have a Yamaha HTR-6160 (From Futureshop in Canada) and Panasonic BD-30 Blu-Ray Player. I can't get the receiver to show TrueHD or DTS-MA on the main display using an HDMI connection.
On the BD-30:
-I have set all formats to "bitstream" and "secondary audio" is off.
-"PCM conversion" is also off
-Just upgraded to Firmware 1.8
On the Yamaha decoder is set to Auto. I've now tried several different movies with TrueHD and DTS-HD MA audio tracks. In each case, the panasonic shows the correct audio track (Pressing the Audio Button shows "TrueHD Multi" or "DTS-HD Multi" as selected in the menu options) but the Yamaha only displays the core audio track either Dolbly Digital or DTS(-ES).
I haven't found anything that says why this shouldn't work. I've also tried changing HDMI cables and disconnecting my TV (passed through Yamaha over HDMI) in case it's some weird HDMI handshake issue.
Any thoughts?
Since neither format works, is the Panasonic failing to pass the full bitstream?
