mr_bungalow
I believe that I have everything hooked up and all the options set correctly. I am running the 6 cables to a yamaha htr-5790. I also have the dvd player set up using a optical cable for regular DVDs. When I don't use the "multi channel input" I get great bass out of the subwoofer, but when I try to play either a SACD or DVD-A I don't get anything.
Can someone help me? I've been through all the options on the dvd player and none of them seem to have anything to do with the bass on the 5.1 outputs. I've also monkeyed around with the menu on the receiver and can't seem to find a setting for the 5.1 inputs.
