I could really use your help. I just got a new Sony Bravia 40" LCD (KDL40V2500) delivered today. Two different times tonight, while I was watching hd channels, the tv has flashed the channel on and off, on and off -- just to be clear, the tv power is not going on and off, it's just the channel. At first I thought the "last" button on the cable remote was stuck and it was changing the channels, but then I realized it kept flashing the same channel (fox 705, grey screen, fox 705, grey screen...). When I turned the cable box off to see if it was the cable, the tv kept doing it. On "video 6", the video source for the cable, it still did the same flashing, but just black and grey, black and grey... So I don't think it's the cable since it still happened when the cable was off. I turned the cable back on and it was still doing it. I switched to a non-HD channel and it was fine, then switched it back to fox HD and it was normal. The second time it happened a couple hours later (also on fox 705, actually), we switched to a random regular non-hd channel right away and it was fine, then immediately switched back to the fox hd channel, and it was fine. Argh!! What's going on? Is my tv broken?
