whats the diff between active an passive filter , im looking to diy or have a custom made
17hz 8th order butterworth highpass filter that would be a physical part that could be permanenty mounted inside the cabinet between the binding post an driver my outlaw audio 976 has low an high shelf filter controls in a 10band para eq for each channel both shelfs are adjustable down to 10hz would or could the low shelf for the sub out help control the sub drivers cone excursion by just setting it to -12db at 17hz instead of using a
17hz 8th order
Active circuits use a power supply for devices that are included, like transistors, op-amps and microprocessors, to name a few because they don't do anything if voltage isn't applied at specific connections. The circuits operate at line level and are often buffered from the pieces they're connected to, so those devices won't affect the performance of the active circuits. The filtering components in a crossover only remove signal- they can't boost it on their own, but an active filter (like a crossover) can because they're designed to provide 'unity gain'- that means the signal level at the input and output are the same. The active circuits can filter at different rates without causing as many problems with the signal and phase shift is one of those- it's the reason the midrange driver in a three-way 12dB/octave crossover needs to be wired with the negative terminal connected to the positive from the crossover (or, the tweeter in a 12dB/octave two way design). The effect of this phase shift can be seen as a dip in response at the crossover frequency in the frequency response graph of a speaker. Having said that, phase shift isn't easy to completely avoid, so the active circuits need to be designed carefully.
Passive crossovers are also expensive, if high quality components are used. There's no way a passive crossover for 17Hz can operate without affecting the sound an octave away, which means that signal at 34Hz is still affected, but not as much as the frequencies between 17Hz and 34Hz.
