Help needed with 4 zone wired Nuvo system
G
G-Force03
hello - I am new to the forum and my audio skills are not the best, so I apologize if my terminology is vague. I am needing some assistance on what sort of receiver I need or can make work to get my home audio system working. There are 4 zones in the house and I have a central bundle with the Ethernet cords and speaker wires which is all brought together into a Nuvo hookup. I have attached a couple of pictures as I know I didn’t explain that very well. I don’t really feel like spending a ton of $$$ on a Nuvo receiver so I was wondering if anyone had any suggestions on how to get these speakers cranking. I appreciate the help!
65172CDC-CF73-4E62-8972-F067CEA05931.jpeg B7F531A5-8706-472B-974C-45D1DBCB86B9.jpeg
WaynePflughaupt
WaynePflughaupt
Your best bet would be to contact a company that specializes in whole-house audio like Home Theater Direct.
Most likely the red/black wires are one speaker in the zone, and the blue/white wires the second speaker.
You will need an ohm meter to determine the impedance of the speakers you have installed. If they show something between 4-8 ohms, you can use them with a non-NuVo amplifier.
The Ethernet cables I’m guessing go to local wall control panels? You probably won’t be able to use them with anything but NuVo.
Regards,
Wayne A. Pflughaupt
