Consider Marantz or Yamaha
The Marantz 8002 puts out 125 RMS and drives HT or stereo well. Has great HDMI 1.3 cpabilities.
125 Watts x 7 Channels All Discrete Amplifier Stage
Current Feedback Amplification
HDMI 1.3a Repeating/Switching (4 in/2 out)
Dolby TrueHD, Dolby Digital Plus, dts-HD Master Audio
Deep Color, xvYCC and SACD Support by HDMI
Up-Conversion (w/TBC) to HDMI with 480I/480P Converter
Assignable Dual Component Outputs
M-DAX (Marantz Dynamic Audio eXpander) for Compressed Audio
HD-Radio
XM HD Surround by Neural THX Technologies
Audyssey MultEQ
Direct-Set Volume, Tuner Preset and XM Preset Commands
Upgraded Binding Posts (Dielectric Protected)
RS232 control and IR Flasher Input
IR Receiver Input and x2 IR Emitter Outputs
x2 12V DC Trigger Output
2nd Zone Audio/Video Output and 3rd Zone Audio Output
Stereo/Mono Switching for 2nd/3rd Zone
RC8001SR Main-Room & RC101 Multi-Room Remotes Included
<16” Shallower Chassis
If you want to spend even more, then the new Yamaha RX-Z11 at 140 RMS is a killer receiver that could also satisfy your HDMI requirements.
Color Black
Surround Modes THX Ultra2, THX Surround EX, Neural Surround, Dolby TrueHD, Dolby Pro Logic IIx, Dolby Digital Plus, Dolby Digital EX, Dolby Digital, DTS-HD Master Audio, DTS-HD, DTS NEO:6, DTS ES Discrete 6.1, DTS 96/24
Video Conversion to HDMI, S-video/Composite to Component
D/A Converter 192kHz / 24-bit
Frequency Response 20 - 20,000 Hz
Multi-Room/Multi-Source Yes
Remote Control Included
Stereo Power Rating 140 Watts x 2
Surround Power Rating 140 Watts x 7, 50 Watts x 4
Tuner XM Radio Ready, XM HD, HD, FM, AM
How much are you thinking about spending? That makes a big difference.
