Help needed buying record player!!!
runlolarunpunk
Looking for a turntable under $140. just listening to records.. nothing else.. it's between these
-Stanton Turntable: T.60X
-Gemini TT-01
-Audio Technica PL50
What do you think of these?
Are there any others i should look at?
Alliey
markw
two questions.
1) Do all these come with a phono cartridge as part of the price?
2) Is your receiver/amp able to handle a phono input? Most today don't. IOW, does it have a position on the selector labelled "Phono"?
markw
A little more info
This model does not even include a cartridge. You'll have to spring for that and possibly a phono preamp as well.
Gemini TT-01
This does contain a cartdridge but you may still need a phono preamp.
Audio Technica PL50
this contains a cartridge and a switchable phono preamp, so this will work with virtually any receiver.
Does this help?
captain_tinker
captain_tinker
runlolarunpunk,
There have been several threads on this subject. Here are at least two of them that I remember:
http://forums.audioholics.com/forums/showthread.php?t=24830
http://forums.audioholics.com/forums/showthread.php?t=22783
In those threads, the following players were mentioned:
http://www.pioneerelectronics.com/pna/v3/pg/top/product/0,,2076_310069826,00.html
http://usa.denon.com/ProductDetails/Turntables.asp
http://www.teac.com/consumer_electronics/P_A688.html
There are others as well, but this is at least a good starting list. Let us know what you decide on. :)
-capT
runlolarunpunk
I don't know what any of this means... i'm much more versed in the camera world lol. What is a phono preamp and a phono cartidge?
Haoleb
Haoleb
Lets start at the souce, A phono cartridge is the the thing at the end of the tonearm that contains the needle. This is probbably the most critical device in the LP playback chain because it is what is actually reading the grooves in the record and translating them into electrical signals which are then turned into sound later on down the chain.
Once the electrical signal is generated by the phono cartridge it goes into a phono preamp which equalizes the signal using the RIAA curve, The RIAA curve is a standard equalization to normalize the signal generated. The signal is equalized before it is cut into the record, therefore it must be "un-equalized" when its read back off the record. The phono preamplifier then amplifies the signal to a higher level suitable to feeding into a standard preamplifier whos only job is to switch inputs and adjust the signal level to match the users input on the volume control knob.
markw
And, to answer your next question...
No, we don't know if you need a phono preamp or not. That depends on what you're plugging it into. You've yet to share that info with us.
BTW, Haoleb did a great job of capsulizing all you really need to know for these two items.
highfihoney
highfihoney
I'll be plugging it into my stereo reciever.
What type or reciever & does it have a switch for phono,if your not sure weather your reciever has a phono section look on the back for a spot labeled phono,if your reciever dont have a phono section in it you will need a phono preamp .
